You can do it yourself. Remove the door panel to disconnect the harness and its held in by 3 10mm nuts.Logan00 wrote:I had someone clip my driver's side mirror so I am buying a used one off of ebay. Its in good condition and is the same color as my car, my question is can I swap the mirror myself or is it something I need to bring to a repair shop?
I would prefer to replace it myself, if possible, to save on costs. If I can, does anyone have instructions?
Thanks
There's a cover behind the door handle, and a cover on the arm rest cubby hole. There's 2 10mm screws behind the armrest and one 10mm behind the door handle. After they're out, pry the door panel off. It's usually easiest from the bottom of the panel.Logan00 wrote:Never removed the door panel before, any assistance?
No problem, that's what I'm here for.Logan00 wrote:Just wanted to say thanks for the help, I was able to change the mirror. Was easier than I expected.
