Replacement Tires
Shocks, springs, sway bars, coliovers, bushings, brakes, wheels, tires - This is the place to discuss G-Series suspension modifications!
C5X2C
Car: 2004 G35
I was shocked to see the replacement cost for stock 215/55WR17. Are there other options for different sizes that would work as well?
C5X2C
audtatious
Actually, they do not seem that bad. $84 and up per tire on tirerack
TireRack
johnsha
Car: G35, Dodge Grand Caravan ES, Saab 9-5 Aero
I put 235/50/17 tires on My G35 Sedan, Conti Touring ContactAS. Improved steering response and cornering , with a high milege allseason tire!
C-Kwik
C5X2C wrote:I was shocked to see the replacement cost for stock 215/55WR17. Are there other options for different sizes that would work as well?
C5X2C
Try looking up the sizes for a comparable to OEM tire(Pilot Sports) for the 18" wheels. Even the 19's. The tire sizes for these wheels are limited so even the cheaper options are still fairly expensive. All of them are actually over $200, except for a few winter tires according to tire rack. Might make you feel better about the prices for yours...
RED_DET
Vendor
2011 Infiniti G37x
Chevrolet Corvette Z06
My suggestion as well. You get a whole lot more choices with that tire size.
Here are specs for OEM:Side wall: 4.7 inRadius: 13.2 inDiameter: 26.3 inCircumf: 82.7 inRevs/min: 767
235/50/17Side wall: 4.6inRadius: 13.1 inDiameter: 26.3Circumf: 82.5Revs/min: 768
Speedometer with the non oem tire is 0.2% too fast.When your speedo reads 60mph, you are actually traveling 59.9mph.
I will probably try the kumho ecsta asx's., $106 ea @ tire rack.
audtatious
I have no idea why Nissan puts these weird tire sizes on their cars. The 2k2 Maxima had 225-50-17's and there are a limited number of tire choices out there in that size. Factory tires are $184ea + shipping on Tire Rack and $200+ locally. I went to a larger tire with a wider patch and they cost less.
Return to “G35 and G37 Suspension, Brakes, Wheels and Tires”
