Replacement Rack and Pinion
DammitBobby
Car: S13 91 KA24DET
Anybody install rack in a 91? I am wondering if I should attempt it myself or pay to have it done. I do have air compressor and don`t mind getting grease on me. I found the Rack for 265.00 not bad when considering it also replaces the inner tie rods.
spitz7985
Car: HICAS S13
I'm doing it right now. Theoretically it's easy, but my tie rod studs are being little ******es, same with the steering column. Overall though, definatly a job you can handle. Look into possibly getting a HICAS steering rack, it has a quicker ratio.
edit: I bought an 18" 1/2" drive breaker bar for this project **insert Time Allen grunt here** ohhh what you can do with 18 inches of leverage
edit2: Craftsmen, of course.
DammitBobby
Car: S13 91 KA24DET
Thanks for the reply. So All I have to do is unhook tierod ends undue the power steering hoses and disconnect from the steering column. How do you disconnect from the steering column?
spitz7985
Car: HICAS S13
There are also two places where it is attached to the crossmember with two bolts each. NISTECH said for the steering column all you have to do is take off the furthest bolt down, then slide it out. Rust will make this a little more trickey.
DammitBobby
Car: S13 91 KA24DET
Ok I found the FSM and it looks pretty easy so next weekend I will try and change it out myself and hopefully gets some pics so other people can do it as well. I had a frontend mechanic look at the car and he recommended the replacement of the rack do to much wheel play and a small leak. The problem I had when driving was the steering wheel would shake at 50 mph and higher also sloppy response. I will replace the outer tie rodswith Autozone`s The Teins you have to replace the inner and outer to work and the replacement rack will all ready come with new inner tie rods.
spitz7985
Car: HICAS S13
Well, any questions, you know where to post 'em!
I bought some underbody rubber spray to help rust proof my rack before I put it on. BUT, I sprayed it right over the other paint and it took the factory paint right off and left me with bare metal. Rust proofing is a good idea, but not the way I did it.
spitz7985
Car: HICAS S13
Looks like you live in AL, so nevermind.
Lucky b**tard... :D
DammitBobby
Car: S13 91 KA24DET
What is rust again?? LOL
DammitBobby
Car: S13 91 KA24DET
Hey by the way I use to live in Cleveland Ohio. The weather up there sux to unless you like cold winters and salt on the road :) I am so glad I live in the south!! Not to mention the women look better too :)
