VStar650CL »
https://forums.nicoclub.com/vstar650cl-u299034.html
Sat Apr 13, 2024 9:32 am
If it's air core (most of the old ones are) just tip it upside down and rotate it. The late gen6 Maxima gauges are infamous for doing that, the fuel and temp gauges on those can actually roll all the way around such that the stop pin keeps the needle from moving upward. The only way to fix them is to pop the cluster out and rotate it. I don't think a D21 cluster would have a stepper movement, so if rolling it upside down doesn't move the needle, there may be something wrong with the tach.
