Replacement headlights for the wife's 1998 I30
endeitz
Car: 1998 Infiniti i30
So my wife has a 1998 I30. It's in good shape, and has never had major issues. She bought it new when she got her first real job and is quite attached to it.
My problem with it is the yellowed, dim headlights. So here's my question:
1. Can I use 1998 Maxima headlights as a replacement (they are cheaper)? The part numbers seem to be different, but I was wondering if they had the same assemblies anyway.
2. Are there aftermarket LED lights that would be brighter/nicer?
I did a search of these forums and couldn't get the exact answer to #1 (I think the answer is "yes" based on some analogous questions). I couldn't get a whiff of an answer to #2.
Thanks in advance,
Ed.
vonscorpio
Car: Current:
15 Infiniti Q50 S
91 Infiniti M30
Past:
16 Infiniti QX50
11 Infiniti G25x RIP
97 Infiniti I30 RIP
01 Infiniti QX4
11 Infiniti G37 Sedan
07 Nissan Maxima
I would recommend just polishing the current headlight lenses -- which is an even cheaper fix.
This kit works well enough: https://www.amazon.com/Meguiars-G3000-H ... B004HCOE72
I would recommend removing the headlight assembly from the car, since they are super simple to get in and out. And the one thing the kit doesn't tell you is be sure to pick up some kind of sealer (clear coat, etc.) for the plastic lenses. Otherwise they will yellow again rather quickly.
centralcoaster33
Car: 1997 Nissan 240SX #5
Sealer? That's a great tip! But what kind of sealer are you talking about? What did you use?
vonscorpio
Car: Current:
15 Infiniti Q50 S
91 Infiniti M30
Past:
16 Infiniti QX50
97 Infiniti I30 RIP
01 Infiniti QX4
07 Nissan Maxima
Rattle-can automotive clear coat (available at Home Depot, or similar big-box stores). Takes a bit of finesse and wet sanding to get a nice smooth finish. Like I said, I'd highly recommend removing the assembly to eliminate masking/overspray issues.
