replacement fuel level unit 90 300zx TT
AtlasShrugged
Car: '90 Nissan 300ZX
Gas gauge isn't working after i drained the tank. Seems like OEM parts are discontinued. anyone know of an alternative before I start taking things apart?
after removing the trim to get to the access holes. I have a separate level sensor from the sending unit
https://www.nissanpartsdeal.com/parts/n ... 30p18.html
nada
AtlasShrugged
Well, I found one.
https://www.megazip.net/zapchasti-dlya/ ... 5060-30P18
We'll see if it shows up. :ohno:
AtlasShrugged
Well that was a bust. Thought they might have a had a stash. Alas, no.
Rogue One
Car: 2011 Nissan Rogue SL
2012 Nissan Rogue SL
2022 Honda Pilot SE
2025 Honda CR-V Sport L
90-96 Nissan 300zx OEM Fuel Tank Sending Unit 25060-30P18
Condition: Used
Price: US $97.50
Shipping: FREE
AtlasShrugged
Sold! thanks Rogue One. $100 bucks is worth a shot.
Rogue One
2022 Honda Pilot SE
:dblthumb:
Hope it works out. Please keep us posted.
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
If it doesn't work, there's this:
https://www.ebay.com/itm/143709817048
or this:
https://www.technoversions.com/MeterMatch.html
Both will allow matching pretty much any sender that fits in the hole to drive your gauge. Same operating principle for both, you set the sender on empty and then make the gauge read "E", then set the sender on full and make the gauge read "F". The smartwork does the rest.
AtlasShrugged
Thanks VStar, this is a good possibility. Finding a nissan gauge that fits the hole is probably not that difficult. Its the float and the amount of travel it needs to take from E to F I think imagine is the hard part. You have to make sure the float can travel freely from bottom to top. One other thing. I've found the Nissan technical drawings for parts are rather poor for making this sort of an assessment.
VStar650CL
Technical Expert
You're most welcome! Yah, the oldest part drawings were all pre-CAD or prehistoric-CAD and largely digitized from paper, so a lot of them are terrible. The beauty of gauge-matchers is that you don't need full travel on the sender, the float just has to hit top and bottom. The matcher won't care if it's only using part of the resistor.
AtlasShrugged
Well i installed it. Tank was half full. On the way to the gas station the gauge read empty. Filled it up and it reads almost full and has been holding there. I'll have to go through this tank to see if its working or not.
