esaydam »
https://forums.nicoclub.com/esaydam-u211618.html
Thu Jan 17, 2013 6:16 pm
Thanks Tiggaman. I did see this thread and a couple others discussing the rattle. I actually saw one where someone claimed that he isolated the rattle to the small removable plastic piece behind the door handle. Haven't tried it yet but he suggested you just apply 2 or 3 layers of duct tape to the back so it's not plastic resting against plastic.
Anyway, the reason for my thread was that I wanted to replace the speakers and there are almost no specs on the factory ones in there. History says it's probably a 2ohm shallow mount 6x9 speaker that I need. Shining a flash light in there looks like it's a 6x9 but no way to tell without removing the door panel. I think I'm going to remove the panel and measure the depth that door panel allows for. Besides the impedence, that's my primary concern, that whatever upgraded speaker I use can fit in the factory bracket and inside the door panel correctly. If anyone has some info on these speakers or a recommendation for a replacement, that would be very helpful.
