Darius »
https://forums.nicoclub.com/darius-u5470.html
Tue Jan 27, 2009 3:29 pm
I considered that as an option for the OEM isolator, but anyone can fill theirs if they feel the need. I am also looking for a cleaner option but haven't found anything that fits the application yet.
I did some searching on some drag racing sites and a lot of racers frown on solid transmission mounts because they put too much stress on the transmission housing causing them to crack. A lot of guys also said that solid mounts should only be used in conjunction with a mid-transmission mount and a rigid frame car (race chassis).
Therefore, I'm leaning towards sticking with the OEM isolator filled with Flexane for simlpicity. I can always find a better urethane isolator solution down the line. For now, I just need to take the slop out of the transmission mount.
