Replacement factory transmission filter for the Q45.
mattd1979
Car: 1990 Pearl White Q45 plain Jane with 266,000 miles. 2015 moonlight white metallic Q70L with 20” wheels, sport brakes and a 5.6L at 58,000 miles.
Are we able to still get a factory replacement external trans filter to replace the existing external filter for a 91 Q? When the previous owners had the transmission replaced under warranty, the dealership also installed an external filter that is bolted to the inside passenger frame rail in the engine compartment. It looks the same as the external filters that came with the 94-96 Qs.
Matt
qship96
Car: 1996 Infiniti Q45
I bought one from http://www.everythinginfiniti.com a few years ago, it was around $90 if I recall- comes as a complete kit with new hoses and bracket- simple to replace, 10 minutes max once on lift. Oddly, very few here seem to ever replace theirs....they seem more concerned about the coarse screen in the transmission pan, when the external filter is a much, much finer filtering medium and will clog light-years before the screen.
Infinitiguy19
Car: 1993 Infiniti Q45 188580 Miles
1994 Infiniti Q45a 240000 Miles
Here is the internal filter kit: http://www.infinitipartsusa.co...=3221
You should replace the external filter with a OEM one which is a bit expensive at $99 from Infiniti Of Scottsdale or $132.32 MSRP. You might be able to use a Magnefine filter in place of the OEM external filter used by the previous owner. But I am a bit confused about the relief spring used to prevent reduced oil flow from a clogged filter.
mattd1979
Yeah, I'm currently using a Magnafine on my Q. I figured that I'd replace it in about 12,000 miles. I'd like to tee in a trans pressure gauge on the outlet side of the filter so that I can monitor the gradual decrease in pressure before it becomes a problem. The 91Q has a couple of additional lines running to and from the filter into the radiator and then back to the transmission. I figured that if it wasn't too expensive that I'd just replace the current external filter with another of the same type to save having to cap off lines. I believe the radiator in the 91 has dual heat exchangers for the transmission fluid. One on each end.
Matt
Modified by mattd1979 at 1:20 PM 4/6/2010
Infinitiguy19
I would tee in the sending unit for the transmission temperature gauge after the cooler (Cooler outlet line).
qship96
Paul Wall wrote:Here is the internal filter kit: http://www.infinitipartsusa.co...=3221
Whats there to be confused about? most oil filters include this type of bypass to allow oil to circulate if filter becomes clogged- just change filter at reasonable intervals and you will not have any issues.
mattd1979
Paul Wall wrote:I would tee in the sending unit for the transmission temperature gauge after the cooler (Cooler outlet line).
I want to use a pressure gauge so that I can monitor the drop in pressure after the filter on the transmission line but I think it would be nice to have a temp gauge also for the transmission. At that point of time I'd guess I could just get a pillar pod set-up and install a trans temp, trans press, and an oil pressure gauge.
Matt
Infinitiguy19
The spring used on the filters seems to be universal but not all transmission run under the same pressure right? How do we know it will put the filter into bypass mode in time before starving the reservoir on the power steering or the transmission's sun gears?
The power steering system on the Q runs at a max pressure of 1000 PSI and the transmission runs at 219 MAX PSI. Now I am not sure what the PSI is for the return system on both transmission and power steering but hopefully someone that does will chime in.
qship96
Return line on both is very low pressure, I bet 35psi or less. You could email magnefine and get answers to your questions, but I have never heard of any issues- Ford thinks so highly of them that they relabel them with a ford part number and require all dealers to install one on every warranty rebuild transmission that leaves a ford dealer.
Infinitiguy19
I just got off the phone with someone at Magnefine. He said when there is a 6 PSI difference between the inlet and outlet the filter goes into bypass mode. The filters were originally designed as transmission filters but then people started using them as power steering filters. He also said people use them as hydraulic fluid filters as well.
They also have a NEW Magnefine Performance Edition Filter for $100 which is made from aluminum and has a replaceable $13 cartridge.
mattd1979
That's some good info Paul. So I guess if I am to get a trans pressure gauge to monitor the pressure, I will need one that reads down to individual pounds to really see a difference so that I can change the filter before it starts to go into bypass mode. Do they even make a gauge that precise for transmission oil pressure?
qship96
just change the filter at recommended intervals {just like any filter} and you will be fine. If your transmission is producing enough wear material to clog the filter quickly......it does not really matter much as the transmission is self destructing and will be toast soon anyways.
mattd1979
mattd1979
I was just reviewing the thread and noticed that I have a duplicate post at the end. I just wanted to note that I don't know why that happened.
Matt
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
mattd1979 wrote:I was just reviewing the thread and noticed that I have a duplicate post at the end. I just wanted to note that I don't know why that happened.
Matt
Click edit on the post which you wish to delete and then click the Delete Button.
