SPIRONIUM wrote:if you have all spherical bushings on your car, the ride feels the same as raising tire pressure all around by 5psi according to this chassis tuning book by henry something or other. Try that and see how you like it
That's a poor assumption.
Spherical joints reduce wheel rate by removing rubber / urethane bushing bind from the effective motion. In that regard they improve ride quality.
The only noticeable effect from spherical joints is the lateral movement the car gets over bumps, ruts, and other irregularities. This is greatly dampened by stock subframe bushings, but if you have aluminum bushings you will pick up some rear walk.
The bushings you are referring to will make no noticeable change to ride quality with the exception of the lower shock mount bushing. You will involve the shock's high speed valving at a faster rate with less bushing deflection. If you have a high gas pressure in the shock then it can get bumpy. Otherwise it's an unsprung vs. wheel rate vs. dampening question.
