Probably gonna have to figure out a custom workaround
I'll need to print this and stick it in the manual.swage tool so I had no trouble attaching the ferrule stop to the ends
Well that's not good. You might first want to adjust the rear brakes as they should slight rub while turning freely. Then I would move onto the emergency brake adjust here at the center cross-member.At the moment if I put all my strength into it, I can rotate the rear wheels slightly while the handbrake is pulled up
