Replacement battery for 97Q45
airman
Car: q45t
Stock battery has 585 CCA.Is it ok to put battery with 600 - 700 CCA? I haven't found more CCA battery with the same physical size as stock. There is 800CCA, but it has additionall terminals which is not encouraged here as I understand :)
Also, is there anything special I should follow during changing Q's battery, like resetting computer etc.?
97Q45t
Car: Viper RT/10, Ford Explorer 4WD
I disconnected my battery many times before. The only 2 things that you'll need to do are reseting the radio stations and the seat memories. Everything else will work like normal.
PalmerWMD
Car: 2004 350Z
Yes its preferred to not have additonal terminals, but I wouldn't consider it a huge deal either.If the strongest battery u can find ... no biggie.
Fred..:)
airman
Car: q45t
thank you, guys
wamQ45
Take a look at Optima batteries.....
airman
Car: q45t
wamQ45 wrote:Take a look at Optima batteries.....
I found an Optima Red Top 750CCA for $100 in local store. But it has a second pair of terminals. Go for it?
PalmerWMD
Car: 2004 350Z
airman wrote:I found an Optima Red Top 750CCA for $100 in local store. But it has a second pair of terminals. Go for it?
that's a lot of money for a battery thats only 750CCA.I like to have a lot fo reserve.For $100 you should be able to get a 900 CCA one.
Fred...:)
airman
Car: q45t
palmerwmd wrote:that's a lot of money for a battery thats only 750CCA.I like to have a lot fo reserve.For $100 you should be able to get a 900 CCA one.
Fred...:)
But this is Optima, everybody praise them here :)This model usually costs 130. How important is high CCA in the hot climate?
airman
Car: q45t
Got 800 CCA Optima for the same price.Thanks!
airman
Car: q45t
Ok, I tried to install it but clamps appeared to be short for this configuration.
Optima has terminals located closer to its center: RedTop U-4,2L
Negative clamp sits ok but positive one is short and cable is not flexible enough to snap on the terminal. It's got fuse and what not in the plastic cover.
So what I think is to buy short extension cable with a clamp on the one end and replace an existing one with it.
The shortest cable I've seen in Autozone was 12in. Is there any problems with that? It's just not going to look neat I guess. Anybody knows where to get little bit longer clamp than standart one?Thanks!
Q45tech
Asking for trouble changing anything about oem positive battery cable.........just find the correct battery.
