replacement antenna for 2015 SL
nabril
Car: 2015 Nissan Rogue SL
Hello forum
yes, there are a ton of posts from many years ago, merged and not, talking about how to replace the antenna with a shark fin, but I did not come across any product links.
I just noticed that the rubber on my Rogue's antenna is heavily cracked, and it should be replaced soon. Or not.
Where can I find a cheap replacement, sharkfin or screw-on?
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
There are no aftermarket replacements that I'm aware of for the dual-connector roof antennas on the gen2 SL's. The best price I know about is NissanPartsDeal at $123.85:
https://www.nissanpartsdeal.com/parts/n ... 4ba0b.html
However, if the antenna works well and the only problem is the rubber gasket;
1) Grab a good gasket from a JY, or
2) Permanently seal the existing gasket with a circle of RTV around both sides of the inner sealing rings. If you film the roof with WD40 before screwing it back down, the RTV will seal but won't adhere to the paint, or
3) Cut your own gasket from a sheet of outdoor foam or vinyl and seal it as above.
nabril
VStar650CL wrote:
Fri Dec 17, 2021 1:24 pm
thank you, but what is JY and RTV?
Rogue One
Car: 2011 Nissan Rogue SL
2012 Nissan Rogue SL
2022 Honda Pilot SE
2025 Honda CR-V Sport L
JY = Junk Yard
RTV silicone (room-temperature-vulcanizing silicone)
Old man
Car: 2015 Rogue SV
Craven Speed Stubby Jr. from Amazon. Just put one on this week. $20+ .
Old man
Car: 2015 Rogue SV
Return to “Rogue Forum”
