Replacement air intake hose
jonmcd27713
Car: 2002 Q45
1988 300ZX Turbo
My flexible air intake tube from the air filter to the throttle body has split. Does anyone know of a suitable aftermarket replacement or can you suggest an upgraded performance air intake system?
Q451990
:welcome: to NICO!
I don't know of anything aftermarket... there's not a ton of aftermarket support for your series of Q45 due to relatively low production numbers. For OEM check out www.orderinfinitiparts.com or www.infinitipartsusa.com
Heath
jonmcd27713
Car: 2002 Q45
1988 300ZX Turbo
Thanks for the welcome! I will check those sites...
GSUjinih
Car: 1993 240SX Coupe
1993 240SX Vert
1994 Q45
I would just likely replace it with stock one. Check out http://www.car-part.com/ for an inexpensive OEM one.
Dmacc420
Car: 2002 Infiniti Q45 Sport
Can't find this part for a reasonable price anywhere.
Just need the hose hose ripped due to having a bad motor mount and being driven hard by last owner. Resolved problem for a while with various rigs. See no other solution than to replace it but part from dealer is almost 500 can't find it for under 3. I just need the large accordion hose that's it. I cant see having to pay 300-+ for that without any other option. Input?
Reason: Fix image link
Rogue One
Car: 2011 Nissan Rogue SL
2012 Nissan Rogue SL
2022 Honda Pilot SE
2025 Honda CR-V Sport L
Dmacc420 wrote:Can't find this part for a reasonable price anywhere.
Fixed image link and merged with existing thread.
Dmacc420
Q451990 wrote::welcome: to NICO!
I don't know of anything aftermarket... there's not a ton of aftermarket support for your series of Q45 due to relatively low production numbers. For OEM check out http://www.orderinfinitiparts.com or http://www.infinitipartsusa.com
Heath
Thanks fot thre welcome I will get some more details on my q and some pics up soon.
I dont want aftermarket I just dont want to pay $400 for a silly little hose that hapoens to be so vital lol.
Was Gonna try my rig again =diameter metal pipe inserted into hose on both ends and epoxy now that the motor mount is replaced. But if I can find it on those sites I will purchase and replace.
Dmacc420
Just a long overdue update. Used a similarly sized metal tube drilled a hole for the vaccum line lined it w rtv and shoved it in both ends of the air cleaner hose. Finished off w some electrical tape and header wrap runs like a dream. Cost me five bucks
Q451990
I'm glad you got it sorted out! With the last Q45 produced over a decade ago, I'm afraid we're all working on our junior fabricator certifications.
