FYI, you can get any ARP bolt, stud, etc for any thing in your car as long as you know the dimensions.float_6969 wrote: I'm also reusing my rod and main bolts, and to my knowledge, ARP doesn't make main studs for the CA.
I was able to get some ARP mainstuds for my built engine, but I can't remember the part #s. But for the guy that is going to be changing his bearings, you should inspect the bearings to see their condition before you up and change them. Most times, the mains are in excellent condition.float_6969 wrote:Just to screw Sean up, my Crank gear came of just fine with a 2 prong pully press. But AFAIK, I'm the ONLY person who was able to get theirs off with out cutting it off. I'd follow his advice and get another, just incase. I'm also reusing my rod and main bolts, and to my knowledge, ARP doesn't make main studs for the CA.
Make sure the bearings surfaces are not scorched or showing copper as well being pitted. Any bearing with a dark grey surface is a good bearing to me. But if you go as far as open up your oil pan, at least change the rod bearings. Leave the rod bolts and mains alone if your bearings appear to be in good condition.originalsin wrote:how do i do that? just look for like sratchs and stuff on them? and what about main bolts/studs replace those or no?
