Replaced water pump... car still overheating?!
gravetolife91
Car: 89 ca18det 240sx, 01 Jetta VR6
My car has been having issues of running hot, and yesterday I found that I was losing coolant from around the water pump, and the whole pump was shot. I replaced it, and the thing still is trying to overheat on me.
Any ideas why this could be happening?
mattscar
Car: 1989 240sx, 1992 Miata
is thier oil in your coolant?
is thier anything blowing out of the exhaust?
87nissanKC
Did you make sure to bleed the air out of the cooling system? Thermostat stuck closed? Is your radiator clogged?
benemorius
Car: s13, s13, eg, e36
All very good suggestions. Don't forget the obvious making sure you topped off your radiator after replacing the pump.
