replaced upper radiator hose and now my check engine light went on, someone help
sideways13
Car: 1989 nissan 240sx SE
okayy so my radiator hose was leaking so i replaced and and right after i drove it to the gas station and i look at my check engine light is on what do i do???
93RB25sx
Car: 1993 240sx
Pull a scanner out it'll read any codes going to your MIL plus there's nothing saying that your light had anything to do with your hose replacement I've had wierd **** go wrong from the start to the end of my driveway
Vegascorbin
Car: 1990 240sx dirt track race car
Check the Temp sensors in the intake maifold. you may have knocked one of them loose while you were working on the hose.
You did pruge the air out after youchanged the hose right?.
What code is it showing?
