rocketman139 »
https://forums.nicoclub.com/rocketman139-u39858.html
Fri Apr 21, 2006 7:43 am
I have a 1995 Infiniti J30 with 105,000 miles. I replaced the timing belt and water pump. I used an actual shop manual to make the repairs. Everything went smooth with the repair. The timing belt appears to line up on all points (the crankshaft and cams). However, the car is very difficult to start and when it starts, lacks power and will not idle. Furthermore, the car appears to run rich. I changed the plugs with new platinum plugs but with no change.
I took everything apart again and examined the timing belt. Again, it appears to be align with the markings. I took the belt off and reinstalled it to see if any improvement would be made. The car still does the same thing. It will not start unless the throttle is floored and even then it is very hard to start (acts like it is either getting too much gas or starving for gas). I do get a lot of smoke after it starts and the spark plugs appear to get really oily (making me believe it is running rich).
I changed a timing belt on a Nissian 300 ZX two years ago with no problems (same engine and timing belt system). The belt was a little difficult to align on the 300ZX (one cam was always off by 1/3 or less of a tooth), but ran perfect. The J30 seems to have the same issue.....the belt looks aligned but is off by less than 1/3 of a tooth on one cam. I have played with the belt several times but can't seem to get it any closer. I did the same thing on the 300 ZX, hoping to get the alignment closer with no success, but the car ran perfect.
The Infiniti dealer tells me that one cam is usually slightly off on the alignment by just a fraction or so (he says it is impossible to be exact and one sprocket is normally off by 1/3 of a tooth or less). However, four of the five points line up exact (including the crankshaft) and the fifth point is very close to the marking (less than 1/3 of a tooth).
I have checked all connections, hoses and even compression and everything seems okay.
Any ideas of what I might have missed? Your ideas are welcomed. Thanks.
