scottydog wrote:It just occured to me that you may be able to pull off the dust cover from the throwout bearing lever and reach in to fix the retaining clip. Sure would beat the heck out of pulling the transmission again.
Any magic tricks on getting the transmission back in? I worked a couple of hours shoving on mine yesterday to no avail...
Jack the front of the motor up just a lil.This give the motor a lil more angle to get the transmission out easierBut be sure not to jack it up to high and break the mounts.Then once all the bolts are loose,just turn the trans where the starter hump is at a 4 o'clock position(passenger side) and pull it out.Same for re-installation.
Also on the no start problem,check your starter connection and make sure its tight.Then if it still don't start,check the switch under the clucth pedal,press it down while your car is in neutral and see if it will start.The car will start even if the throwout bearing is installed wrong,because it has nothing to do with the motor.
