izmyttz »
https://forums.nicoclub.com/izmyttz-u64267.html
Fri May 25, 2007 10:10 am
There was slight rust under my T Top Center bar...so because it looked like crap I decided to replace it. I believe it was around 65.00 on Ebay New. Here is the process and pics. Enjoy.
Peeling and looks like crap
A little rust
More Rust
Ok Now after I dropped the headliner and removed about 8 or so 10mm bolts I was able to remove the T Bar...Hope you guys are ready............it's bad........but not all the way through...
The new bar next to the old one
I had a couple things I used to prep the surface for primer and then paint. I had this primer that turns rust black and keeps if from rusting..then I used some auto primer on the black primer to prep it for paint. Before all this I had to remove all or any rust that I could with a screw driver or a flat object. It wasn't pretty. Here are some picture of the car newspapered and taped off.
After it was done I forgot to take pics..I'll post them later. But you can see how good the new one looks next to the old.
