Replaced TC rods w/ Poly, Still have popping noise....
RatedR
Car: my beautiful young asian schoolgirl wife! Hehehheheeh, yes, its a "field trip". Yeah, a &q
Just got done having a set of Prothanes from PDM pressed in. I noticed that steering is a little more crisp, but the front end still pops when I do quick sharp turns. I took it to the parking lot and tried to jerk the car around to see the difference. Any ideas as to what else could cause the popping noise? Or is it normal for the poly to make that noise?
180fan
Car: 89 fastback
you get an alignment?
RatedR
Not yet, just wanted to get a heads up on any parts I might need to replace before heading down to the alignment shop. I think it could be my lower ball joint, seeing as how it pops under sharp steering inputs.....then again, the t/c rods are the ones that "pop".
bige240
that noise sounds like it is the ball joints...they make a kind of CLUNK noise when you make a hard turn, when they are bad....you'll never find the rear ball joints, you'll have to buy the whole arm....or I think you can replace the rear ball joints with the front ball joints from a sentra... If they have never been replaced I would do that before the alignment.
RatedR
If the noise is coming from the front, why would it be the rear ball joints?
lbrowne
You can also have worn strut mounts - not expensive. As you turn, stress is put on this unit in different degrees which can cause a popping noise if they're worn bad.
Jasong
I vote that it's the ball joints.
bige240
My bad...I thought you said rear....but you have ball joints in the front too, those you can get anywhere...
RatedR
Yeah, I figured it might be the ball joints. I've replaced those before but on my previous 240. Just wanted some input from someone w/ the poly t/c bushings and see if its normal.
180fan
Car: 89 fastback
Yeah probably the ball joints, but let the guy who's trying to upsell you after the alignment give you the verification of that lol.
nissanman04
Car: '90 240SX, '95 Subaru Legacy
strut mounts are still a possibility, ive replaced my tc rods, entire control arms, tie rods and i still get popping on tight turns
Fahaka
Car: '96 S14 '07 Versa
nissanman04 wrote:strut mounts are still a possibility, ive replaced my tc rods, entire control arms, tie rods and i still get popping on tight turns
Check your rack...bushings, fasteners etc...
