Replaced struts, but still noise!!
bvgetiw943
Car: 1996 i30
Ok so a few weeks ago I replaced the rear struts on my 1996 i30 because I was hearing excessive noise from the rear of the car. Once the struts were replaced the noise completely went away.
Yesterday I started to hear a different noise coming from the rear and have determined the noise is coming from the struts. The noise becomes present when I go over bumps. It's a rattle noise.
Is there anything I can adjust to fix this noise like the top bolt of the strut (in the trunk)? If I tightened the top bolt of the strut too tight, would it cause this noise?
Thanks
MinisterofDOOM
Car: 1962 Corvair Monza
1961 Corvair Lakewood
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
Could be the upper bushings. Did you get the rear aligned after the struts were replaced? If not, it may need it.
Of course, it's also possible that the noise isn't related to the suspension at all...hard to tell without hearing it in person.
Nrw
Car: 1998 Nissan Maxima SE
Align the rear? LOL
Only thing back there that can be adjusted(factory set up) is the centering of the rear beam. The camber and toe are not adjustable in the back.
MinisterofDOOM
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
Ooops. I'm used to my cars with real suspension in the rear.
bvgetiw943
Car: 1996 i30
I've been doing some research and heard from multiple sources that the bearing plates (which i did not replace when i replaced the struts) could be causing the noise.
Has anyone experienced this problem?thanks
Nrw
MinisterofDOOM wrote:Ooops. I'm used to my cars with real suspension in the rear.
touche'
