Jacko3 »
https://forums.nicoclub.com/jacko3-u85814.html
Mon Oct 27, 2008 10:34 am
Nate:
My mechanic is a magician--he does things that befuddles me, and yet it works.
First he took a long scissors-like surgical instrument, grabbed a dry rag, and at some distance, sprayed the rag very lightly with some stuff from a can---possibly a cleaning fluid--make sure the spraying is occuring at some distance.
Then, he removed the air intake and z-tube, turned the ignition switch to on without starting the car, then he put the car in gear, then he depressed the accelerator pedal, and lo and behold, the flaps of the throttle body, magically opened. Then he turned the ignition back to OFF while he cleaned the inside of the throttle body.
Then with the rag, he carfully cleaned inside and around the flaps and deep inside the throttle body, without ever spraying again that stuff in the can on the rag. After this, he repeated the same process to open the flaps in order to close the flaps.
Then he used the computer stuff they have at the dealership, while the car was running, to reset the idle learning sequence once again. He made it look easy but i was not fooled one bit by his technique---I told him that only he will be doing this for the rest of the life of my car.
Modified by Jacko3 at 1:56 PM 10/27/2008
