qship96 »
https://forums.nicoclub.com/qship96-u3104.html
Sun Apr 30, 2006 10:05 am
While having the tires rotated and balanced,had them check the brakes as by miles since last rear brake job were adding up{ 51,245},sure enough,rear pads were about to hit the wear sensor- replaced with pads I got from Joe- funny,only 1 inner pad in the new set has wear indicator clip-whereas the old pads had one on each wheel{ also factory pads that were done at ther dealer} why the change?
Also,looking over my history,it seems I go through rear pads every 51-54 thousand miles- fronts have always been between 65-68 thousand miles-like clockwork! by the way,2 rebalanced michelin exaltos required NO weight on outside rim,other 2 took 10 grams-after 12,000 miles still wearing very slowly and evenly.
