replaced my timing belt....Aaaaahhhhh
yourmomsrps13
Car: Drifting ruined my life since 03' 240sx CA18DET
I just replaced my timing belt with a greddy/trust strengthened belt now my car runs so smooth its not even funny, SR20s sound rough and sh@tty compaired. This might have fixed my idle problem but i also pluged the PCV valve as it was shot and im running a catch can. Then i went ahead and installed my Z32 maf and a boost controller(11psi) oh and some newly painted valve covers ; )she feels like a whole new car, idk if the exhaust cam was off by one tooth or if the belt was that stretched but wow what a diference. Im going to head back to the dyno soon and see where im at now considering i made 187 at the wheels when it was 7psi and running sorta crappy, plus i can use the dyno for free whenever.
PS: im still off the charts lean at idle
Modified by yourmomsrps13 at 7:07 PM 8/30/2006
driftin8ez
Car: 92 Coupe, Turbo Miata
Your title got me a little worried with the Aaaaahhhhh. I thought you broke something. But from the sound of things it was a sigh of relief. Good to here your ca is better than ever!
yourmomsrps13
yes, sigh of relief, but i still dont understand why im so lean at idle and why when shes cold and i give her a min to warm up and then i go to drive away and she wants to stall if i give it anymore then 15% throttle. and i replaced my coolt temp sensor again
driftin8ez
ya mine does the samething. If i give it any gas when shes cold even a little it will sputter and bag down until i let of the gas then it will idle fine. This only happens when the engine is cold. As soon as it warms up all is fine.
yourmomsrps13
im still getting that and when im just cruising and i give it gas and the boost climbs to 0-1 psi i get a sputter and tiny blue flames out my exhaust, but i can gas right past it
rico05
Car: 1992 RMS13 w/ CA18DET
I get that as well. I am hoping it is my vented BOV or bad FPR. Both are being fixed the week.
Dattebayo
Maybe a malfunction of the warm-up switch? The sensor on the middle valve cover-side of the intake?
