I replaced my old injectors, and I noticed a rubber wire was really messed up, so I cut the end, still have to cut the other end, but no more hesitation now..
Took me about 30 minutes to replace the injectors, you only need to remove 4 bolts, and 2 tubes, and the plugs to each injector...
My old o rings were all messed up, cracked and worn, and the old injectors had a ton of rust on them...
