REPLACED LOWER GRILLE WITH ALUMINUM MESH
Larz
Car: 2019 Q70-L RWD
Today I removed the gray plastic lower grille section and replaced it with diamond mesh aluminum.
I removed the lower grille piece and then cut out the center of the grille along the border with a jig saw. That left me with just the flat plastic border on all sides from the inner edge to the fog lamp. Just a square border with outer the corner and fog lamp bezel still intact. This way. the original shape of the grille was retained and the fog lamp and adjacent corner were easier to cover.
I purchased 2 sheets of diamond aluminum mesh from 'customcargrilles' on Ebay. Each sheet is 4" x 36" which is the perfect height to fit inside the empty plastic shell I created by removing the guts of the original grille. It comes unpainted as seen below.
http://www.ebay.com/itm/190992827812?ss ... 1439.l2649
They have a variety of different styles and this mesh is also available with larger openings. Here is a link to the assortment they offer:
http://www.ebay.com/sch/customcargrills ... pg=&_from=
Mine allows 65% air flow, so it's an increase in air flow with this mesh instead of the solid plastic it replaced.
It was just a matter of trimming the mesh so it fit neatly in the shell, cutting around the fog lamp bezel. I used tin snippers and the mesh cuts very easily. Once the mesh fit nicely, I used thin plastic zip-ties along the top and bottom to hold it snug inside the frame.
Once this was done I used Krylon Color Master paint & primer in one - gloss black. I painted the entire piece - the frame, the mesh, the fog lamp bezel - front and back. The zip ties are only visible if you bend over and stick your face in the grille and look for them. The entire grille matches the car perfectly as if from the factory. It's hard to see the mesh in pics but it looks great to the eyes.
Total cost for the project was about $25 for the mesh and the paint.
outer corners:
Mesh installed with space left to re-install the DRL:
Now the entire lower grille is glossy and black instead of the grey filler piece inside the main bumper. What a brilliant change for just $25 !!
EniGmA1987
Car: '06 Infiniti M35 Sport
Quite interesting of an idea, looks better than the cheap plastic mesh for sure. Can you add a pic of the car from a bit farther away too?
Larz
Car: 2019 Q70-L RWD
EniGmA1987 wrote:Quite interesting of an idea, looks better than the cheap plastic mesh for sure. Can you add a pic of the car from a bit farther away too?
The sun is gone now, but I do have another pic from the right side with sunlight hitting the grille. BTW, I didn't change the center section of the bumper - left the main air dam completely open as it was.
I shall try to snap some full frontal pics facing the sun tomorrow after I give the black beast a good cleaning.
Larz
Car: 2019 Q70-L RWD
I have come to the conclusion that my GoPro is too sensitive to just take a sunlit pic. It seems to show too much detail with regard to how much sun is reflected back from the grille. To the naked eye. it's a uniform reflection of black / chrome mesh that looks stunning, but the camera shows different amounts of shine across the front regardless of the angle or distance. Here is a before (when the car was still at the dealer) and an after (today) of the front end:
Sorry Enigma, mate. This is about the best I can get for you.
agee
Car: 2010 M35S
Looks nice, I cringed a little when I saw the Al mesh touching your paint.
Try taking a pic with lots of light at your back and with a darker background. The light background is messing with the exposure calculation.
stm37s
Car: '12 Chrysler 300 SRT8
'11 Infiniti M37 S
'06 Range Rover HSE (Wife's)
'12 Chevy Camaro LS (Wife's)
'95 Chevy Impala SS (sold)
'04 Chevy Impala SS (sold)
'12 Hyundai Veloster (Daughters)
very nice bruh
Larz
Car: 2019 Q70-L RWD
agee wrote:Looks nice, I cringed a little when I saw the Al mesh touching your paint.
The mesh doesn't touch the bumper or the paint anywhere. It's secured inside the frame of the lower insert. I cut out all the lower insert along it's frame so I ended up with a four-sided empty insert frame and the frame is all that is touching the bumper and paint - just as it was before the mod. The frame is very thin and that gives the impression that the mesh is touching the paint / bumper.
