silkysmoothyjud wrote:You did not buy new ones, did ya? No need to answer, I did the same thing, thought I was real smart saving all that cash until I bought brand new ones, and that rough idle went away. Bad coil in the injector, but it will still ohm out ok....Anybody wanna bet me?
I'll take that bet. If it doesn't run bad till closed loop, its not the injector he replaced. At that point he's running the full gambit of MAF to ECU problems, almost any sensor in the intake or exhaust system. You'll wanna have that sent to a tech for a proper diagnosis.
I suppose some quick things to do are to make sure you ran all your wires correctly on reassembly, and nothing's unplugged, then check your timing, and anything else you had to move around to replace that injector, even if it seems mundane.
