punkrock1992 wrote:Okay sorry for the delayed response y'all, school and work have been unkind. What I have done so far: new plug, new coil pack, new ptu, verified spark, getting fuel, compression(160), new knock sensor and harness, cleaned connections, replaced injector, cas connection is tight. But still the cylinder is not firing. And I'm lost.. Got fuel, spark, compression... So any advice would be greatly appreciated.
How do you know your getting fuel to that cylinder? Is the plug wet?
I had an issue once, where an injector went bad. Now these are the newer style, so I checked everything, spark, compression, orings, etc... The injector ohm'd in spec, it clicked, did everything it was supposed to, well except one thing. So as a last ditch effort, I decided to swap the injector to a different cylinder. Sure enough the problem followed. I had to explain to coz about it since it was still under warranty, he tested it, even flow tested, came back good.
He ended up sending me a new one, just cause he just a cool guy, sure enough, fired right up without a dead cylinder. Don't rule out an injector if you checked everything else.
