replaced idler pullies and theres still a whining sound wtf
localz32
Car: 1996 300zx
my car was making a whining sound so i did the 120 k service replaced timing belt and idler pullies tensioner bearing etc. the first two days it was fine the noise went away and for the past 3 days it came back when i start the car and its cold and anytime it goes above 5k rpm and sometimes on warm starts. does any one know what it might be.
cmesurf
Car: Infinitis, 03 FX35, 07 g35 sedan, 05 FX45, 09 G-vert & 14 Q50S Hybrid AWD
check water pump bearing...
localz32
Car: 1996 300zx
cmesurf wrote:check water pump bearing...
water pump is fine i checked it
cmesurf
Check all bearings is starter, AC compressor etc
t.mcginley.jr
Car: 2002 Nissan Altima SE 3.5
1990 Nissan 300ZX NA 2+0
1966 Ford Mustang
What kind of whining sound? Is it like an electric kind of whine or more like a metallic/screeching sound?
(a video would be great, but if not its ok)
localz32
Car: 1996 300zx
alright tomorrow i will inspect everything
localz32
Car: 1996 300zx
t.mcginley.jr wrote:What kind of whining sound? Is it like an electric kind of whine or more like a metallic/screeching sound?
its metallic like a bearing thats why i changed the tensioner pulley and the idlers it stopped for 2 days and I checked everything but it seems its the tensioner pulley again witch was just replaced a week ago with a oem.
nissanfreak12
Car: 92 300zx 2+2 TT
Are you sure your not rubbing on the covers? Have you checked the alternator? Try taking off all the belts and see what happens, I had a sound like that, annoying little sound. Ended up being the alternator.
How is the fan clutch?
localz32
Car: 1996 300zx
nissanfreak12 wrote:Are you sure your not rubbing on the covers? Have you checked the alternator? Try taking off all the belts and see what happens, I had a sound like that, annoying little sound. Ended up being the alternator.
fan clutch is fine i actually just replaced it i will check the alternator though thanks
Ziggy1621
Car: '90 Z32 TT (Shibui)
'90 Z32 2+0 NA
'68 311 Roadster
2004 Rx330
2011 BMW 550i (TT)
You can do an old, but good, trick. Get a hose with at least 3/4" inner diameter and a couple feet long. Put one end to your ear, and move the other around your engine bay until you locate they exact culprit of the sound :)
nissanfreak12
Ziggy1621 wrote:You can do an old, but good, trick. Get a hose with at least 3/4" inner diameter and a couple feet long. Put one end to your ear, and move the other around your engine bay until you locate they exact culprit of the sound :)
Wooden broom handle, screw driver, all that kind of stuff will work the same. You just need to have the sound travel in the pin pointed spot.
t.mcginley.jr
1966 Ford Mustang
If it's not the bearings/idlers, WP, or belts then it could just be the AC compressor itself
localz32
Car: 1996 300zx
I checked every belt one by one and it turn out the alternator belt was to tight so put less tension and it stopped.Its weird because I thought the tension had to be like on most other cars. thanks for the info guys and i used the hose technique.
t.mcginley.jr
1966 Ford Mustang
Yeah when belts are too tight they make a weird noise. I had that same thing happen when I overtightened the AC compressor belt when doing a timing belt job on my 92 Maxima. Glad you got it worked out
Ziggy1621
'90 Z32 2+0 NA
'68 311 Roadster
2004 Rx330
2011 BMW 550i (TT)
Glad you got it! :mike
