replaced head gasket - does this sound normal?
dhen
Car: MGA w/ CA18DET
Hi everyone,
Hope Thanksgiving is going good for everyone.
I finally got the CA running again and I'm looking to get some honest feedback.
When I first fired it up, it seemed noisier. Not sure if this is normal or not. I'm hoping it was just a matter of getting the oil circulated as I had the head resurfaced and cleaned:
http://youtu.be/jUhCm83ZaSA
It got smoother once it warmed up.
http://youtu.be/PQyef4N_Oo0
Oil pressure is great.
Thanks
D_Stirls
Car: Nissan 180sx 1990 Ca18det
When you changed the HG did you change the Timing Belt as well? If so what brand did you use? I know with Blue Gates belts develop a hum with the RB's, not all of them do but some of them do and its quite pronounced.
oda70
ttp://youtu.be/P_rJoz7r2f0
Nice feeling getting it running again. :) noise lifters, pressure building up?
Needs more cam like mine
float_6969
sounds perfect to me!
sjbsuperman1425
Car: 1989 Nissan 240sx
CA18DET
It kind of sounds like something I had happen after my last timing belt replacement. In my case, I tightened the upper timing cover bolts up in a strange order and caused a similar sound. I loosened them all and then re-tightened them in the correct order and the noise went away. It was awhile ago so I'm not sure if you sounds is the same sound i heard. just thought I'd give my .02.
dhen
Car: MGA w/ CA18DET
Yeah, I kind of chewed up the timing belt because I put it on too tight and the teeth rubbed on the cover. I adjusted it right and have ordered another one. The sound I noticed sounded more mechanical and was loud when it was cold, but if no one thinks it's out of the ordinary, I'm not going to worry about it.
I'll post another vid if it does something obvious.
Thanks
dhen
Car: MGA w/ CA18DET
I swear I know this engine now. I thought I heard a slight metallic sound li e I said, but I wasn't sure if it mattered. Today I replaced the timing belt today and put on a different tensioner and made extra sure the pulley was tight enough. The sound is gone. I think it was the pulley.
Nice to actually be able to solve something...
float_6969
I'm glad you got it figured out!
