blackout240 »
https://forums.nicoclub.com/blackout240-u99775.html
Wed Jul 02, 2008 2:40 pm
well thats true but there is no headgasket leak, it has a brand new one. my compression is good on all cylinders (150), not the best but consistant. i went and talked to a nissan tech today and he said it would most likely be a bad distributer, he said that he has had customers with this problem many times and it always turns out to be that. we also did a diagnostic test by using the ecu and it threw up a knock sensor code, so we replaced that and still nothing but it did make it run a lil better. then we checked for anymore codes and it threw up a bad mafs code, but whenever you start it up and unplug the mafs it drops idle and wants to die but doesnt....so that is working properly
