2011 Nissan Murano Crosscaboilet
Replaced driver's door actuator and currently have the door panel off - with door airbag disconnected, door light disconnected and mechanical door/opener disconnected.
Sitting inside car, windows up, shut off engine.
Open door, get out (with key FOB), using FOB - lock door by depressing the FOB button once (quickly pressed with no additional time pressing the FOB).
Car is locked - on first pull of handle to test if it is locked. If I pull handle quickly again, the door is unlocked and all windows go down automatically.
Repeated this several times with both FOB's - same result.
If I wait a couple of seconds on the second pull, the door opens but the alarm goes off - door is unlocked and will open - then all 4 windows go down.
What the solution / problem?
