ARKQX33V6 »
https://forums.nicoclub.com/arkqx33v6-u165721.html
Thu May 19, 2011 5:13 am
Re:CV joints.
The meeting of the drive faces may be worn, a new set of boots will be needed at least. Use OEM. Look for wear at the drive and driven sides/ends.
Replacing is a matter of dis-assembling from outside to inside of the drive line. When re-assembling, check as you go, pre load the wheel ends as by the book, do one side at a time.
While your at it verify struts, shocks, bearing and links.
