The engine is a RB25, with the RB25 transmission. it ran fine and didn't make a noise before I switched out the stock clutch and flywheel for an unorthodox lightened flywheel (aluminum with steel insert) and 6 puck clutch (both were used but with at least 60% life still on them) now it makes a RPM dependent noise when the clutch is engaged and disengaged. Also when driving the transmission pops out of gear with a slight touch where it used to be hard as a rock and would not release without the clutch being depressed.
edit** flushed fluid, no noticeable improvement. when taking it around the block, i noticed that the noise goes away under deceleration. it only happens on acceleration and at idle with the clutch in or out.
here is a vid with the noise and showing how it pops out of gear when driving now"
http://s2.photobucket.com/albums/y19/Te ... 161222.mp4
Thinking possibly the pressure plate is bad? something didn't go back together right? toss it and out the stock s*** back in? toss the pressure plate/puck clutch and put the stock exedy i had and it's pressure plate back in?
any info helps before i have to tear this thing back apart and put the old stuff back in, which is a bear to do on baking hot concrete by yourself.
