johnmeikle24 »
https://forums.nicoclub.com/johnmeikle24-u107649.html
Tue Oct 07, 2008 5:10 pm
Recently I noticed a repetitative whining noise emmiting from the belts on my 1998 QX4. As far as i can tell it sounds like its comming from the passenger side of the engine around the accessory idler pulley. Here's what i've done to try to fix it:
1. Assuming that it was a loose belt, I checked the tension and tightened them both slightly. This did not help. 2. Having read some other posts on this forum I noticed that the idler pulleys can be somewhat problematic. So, I replaced them both. This did not help either. 3. both drive belts were replaced when I did the timing belt at 105k (ive now got 131k) The belts appear to be in excellent condition.
My last guess is that the crankshaft pulley is going bad (harmonic balancer?). When i look at the pulley it seems to have a SLIGHT wobble (by SLIGHT i mean that it is barely noticeable, maybe 1/32 of an inch).
My questions for you all:
1. Is it common for the crankshaft pulley to have problems?2. Is a SLIGHT wobble normal? 3. Is the crankshaft pulley relatively easy to replace (i'm pretty comfortable with moderate repairs, had no trouble replacing the idler pulleys etc.)3b. What size socket goes over that outside nut? I dont have a socket large enough to fit over it so I'll have to go buy one). Does it just slide off like the idler pulleys or is there more to this job?4. Am I missing something?
Thanks for any help you may have. I'm beating my head against the hood trying to figure this out!
