Densetsu »
https://forums.nicoclub.com/densetsu-u91979.html
Thu Jul 18, 2013 10:37 am
You'll have to re-calibrate your sunroof's closed position... it forgets this whenever the battery is disconnected. Close the sunroof all the way. Once it's closed, hold the switch in the 'close' position for 5 seconds... it should make a click sound. Once this is done, it should work as normal.
