Replaced Battery now car will not start
jcassady
Car: 2007 infiniti m35x
i replace the batter in my 2007 infiniti m35x, which btw was a pain in the a**, now the car wont start and im confused why? someone please help. i can unlock my doors and headlights are working.
ezb57e
It wont crank over, or it wont do anything? Cranks but wont start?
Key fault light on in dash?
jcassady
it wont do anything and nothing shows up on the dash
jcassady
key fob does not work either
ezb57e
The dash is dark?
Blown fuse link at battery?
You need a voltmeter and a test lamp.
Good luck
EniGmA1987
Car: '06 Infiniti M35 Sport
or maybe the ground is not tightened enough. There are lots of people here who thought such a small thing couldn't possibly be the issue, yet tightening the ground just a bit tighter fixes all sorts of strange electrical problems.
Larz
Car: 2019 Q70-L RWD
EniGmA1987 wrote:or maybe the ground is not tightened enough. There are lots of people here who thought such a small thing couldn't possibly be the issue, yet tightening the ground just a bit tighter fixes all sorts of strange electrical problems.
Allow me to second that. I had a similar situation. The cables were actually tight against the battery terminals. However, the ground cable was not seated flat against the battery itself. I had to hold the cable down flat against the battery while re-tightening completely and all the weirdness stopped. I never would have believed it if I hadn't seen it for myself. Just take a few moments to check ALL connections and be sure they are fitted properly AND very tight.
veery
Car: 06 M35x Umbria Grey
I third this. You replaced the battery. Check first those connections which you loosened and tightened.
Next the main fuses. Sometimes you can draw a big spark when removing/connecting those terminals and pop a fuse.
Make sure your new battery is good!
TDot
Car: 2008 M35X, Lakeshore Slate/Tan
You want to third this two months later? Jokes. I'm sure he got his car started in the past two months lol, although it would have been nice of him to post an update if the help he received fixed the issue or not.
Welcome.
Costee
Car: 2006 Infiniti M45 Sport
2012 Nissan Murano SL
TDot wrote:...he got his car started in the past two months lol... it would have been nice of him to post an update if the help he received fixed the issue or not.
Yes, it's sad some only want to receive and never to give.
agee
Car: 2010 M35S
TDot wrote:I'm sure he got his car started in the past two months lol
Maybe he hasn't. RIP jcassady's car.
szh
Car: 2018 Tesla Model 3.
:lolling:
Z
