Replaced battery now 07 M35 won't start
ecberg
Car: 2007 Infiniti M35
Liquid Platinum
I have an 07 M35 and just replaced the battery in it. After replacing the battery, I tried to start it but when I push the button, nothing happens. I followed the typical procedure for replacing the battery, removed negative first, cleaned the terminals, connected positive first on the new battery, etc. The battery has some amount of charge because the interior lights work and the brake lights work. I have tried both of my keys. I have tried them both in the slot as well. The dash does not show that it even sees the key. I checked all the fuses and they are all okay. Does anyone have any ideas? Please help!!
TDot
Car: 2008 M35X, Lakeshore Slate/Tan
Is your old battery completely dead? Did you try to put it back in to see what will happen? Did you try to jump it to see if it turns over at all?
I had an odd issue on my truck similar to this and it turned out to be the actual terminal, not connection, on the battery was loose. So check that.
If all else fails bring it to AutoZone or something to check the battery charge regardless if it is new or not.
ecberg
Liquid Platinum
That was something that I was going to try today. The car would turn over with the old battery. I was either going to try charging the new one or putting the old one back in.
07sportm35
Car: 2007 Infiniti M35 Sport
Try "jumping" your car with another vehicle. If that works, then it's your battery.
ecberg
Liquid Platinum
I tried a fully charged battery and it still doesn't work. I noticed that the key fob won't lock/unlock the doors either. Is there any way to register the keys without going to a dealer?
CPJ LB
Car: 12 G37X Sedan- stealthy modded
14 Altima 2.5
08 Tahoe
06 M35 S (gone)
14 Versa 4dr (gone)
how long has this been an issue?? what symptoms did you have that lead you to change your battery, originally??
ecberg
Liquid Platinum
This all happened yesterday. I felt that when I started my car, it would hesitate a little before starting, which it never used to do. I drove it several times during the day and then in the evening after sitting for several hours, I tried to start it. When I pushed the button, I could hear a clicking and the engine didn't try to turn over. I tried that a couple of times, so I decided to go get a battery. I changed the battery and now here I am.
CPJ LB
14 Altima 2.5
08 Tahoe
06 M35 S (gone)
14 Versa 4dr (gone)
ecberg wrote:This all happened yesterday. I felt that when I started my car, it would hesitate a little before starting, which it never used to do. I drove it several times during the day and then in the evening after sitting for several hours, I tried to start it. When I pushed the button, I could hear a clicking and the engine didn't try to turn over. I tried that a couple of times, so I decided to go get a battery. I changed the battery and now here I am.
...regarding the new battery you purchased, is it within the required specs for our cars?? It could just be a 'faulty' battery...just like mentioned before, try taking the 'new battery' to a shop in order to get tested.
...you mentioned the key fobs also...try changing the key fob batteries also...
CPJ LB
14 Altima 2.5
08 Tahoe
06 M35 S (gone)
14 Versa 4dr (gone)
this might also be related to the camshaft and/or crankshaft position sensors -- I've heard M owners having issues of their cars not starting due to the sensors going bad...
The Bodyguard
Car: 08 Infiniiti M35 black loaded custom VIPDOUT
08 Infiniiti G35 S sold 92k miles
08 Infiniiti M45 S sold 78k miles
07 Infiniiti M35 traded 53k miles
95 Infiniiti J30 sold 155k miles
Location: Cypress, TX (Houston) o.g. from southern cali (North Hollywood)!!
Start with the battery in your key fob!! :gotme
ecberg
Liquid Platinum
Tried a new battery in the key fob and still nothing. I'm calling the dealership in the morning.
jonlex99
Car: 06 Infiniti M35X, 06 Kawasaki Z10r, 06 G35s coupe 6smt with the 19 inch forge wheels. 02 Lexus LX470
Any update on your problem with the M not starting?
ecberg
Liquid Platinum
So I had it towed to the dealership and they replaced the power distribution unit and the intelligent key controller. It took them 3 days to get it running again. I am going to pick it up in the morning and will hopefully find out more details. On the bright side, I have been driving a brand new G37 sedan for the last 3 days!
