OkieInCO »
https://forums.nicoclub.com/okieinco-u247512.html
Tue Feb 07, 2017 6:55 pm
Wow. This is EXACTLY what happened to me. I was replacing the headlight bulbs in my '02 QX4 and had to remove the air filter unit to get to the driver's side bulb, and the battery to get to the passenger side. And, sadly, I still have problems with the driver's side headlight, meaning I probably have a ballast issue.
Anyway, I had the same problem with the radio afterwards. I could control it from the steering wheel, but none of the controls on the radio itself would work. And, it beeped every time I turned the ignition on. I'll try the battery reset, and see if that works.
I love this forum!
