Replace your Sparkplugs!!! NOW!
Kenrik
Car: Nissan 240SX Coupe
Infiniti G35 Coupe
Nissan Versa Hatch
This is for high mileage G's.. Replace your sparkplugs!!
My G has been having some rough idle and the gas mileage has gone down in the past 35k miles since I bought it last year (From 21-22 MPG to 18.5 - 19 MPG)
My car is at 80K miles and I did mine yesterday, WOW. The plugs looked awful, there was blowout on the stems and the tips on all the plugs were slightly melted. I checked the gap on the plugs and it was as follows (Stock gap is .44) - 50,55,48,52,56,49
Ignore anyone who tells you that they are good until 80-100k they are WRONG. From the look of these plugs they should have been changed at 60k.
The idle is smooth now and I gained Tons of HP in the top end (4.5k - 5.5k it pulls hard)
(Butt Dyno says 15HP)
So the moral of the story is: High mileage G's change your plugs!
SVTCOBRA
Car: 2018 Q60 AWD 2023 F150 4x4 5.0 FX4
Thanks, good to know. one of my sedans is at 51k, so I'll check them at 60k
Kenrik
Infiniti G35 Coupe
Nissan Versa Hatch
SVTCOBRA wrote:Thanks, good to know. one of my sedans is at 51k, so I'll check them at 60k
Well it's only $30 for the stock plugs and $60 for NGK Iridium. IDK why people don't change them until 80 - 100k it's not like a clutch or anything that will cost you a few hundred.
That reminds me.. Remember that post on shifting techniques? Well there was a video in there with some kid driving a Mini and I remember him saying "it's better to let your wheels spin rather then feather the clutch because a clutch is more expensive then tires" Well he lost all credibility with me when he said that. Maybe for his crappy little mini with 195/55/14 but not for a real sports car. Just one tire for a G35 can cost more then a clutch kit.. ($250 for a stock clutch kit)
Anyway I know it's off topic but it just came to mind.
IlsG35
Car: 2003 graphite 6speed G35
yea i did mine at 59853 miles n they looked like they needed to be replaced already... so yea they not 100k plug they 60k plugs...
zozoka1212
Car: 08 Infiniti G35x
BMW engine!!
Cost you a lot more to work on.
zozo
ACoupe
I replace my plugs every week...
Kenrik
Infiniti G35 Coupe
Nissan Versa Hatch
zozoka1212 wrote:
BMW engine!!
zozo
Nope, a clutch kit for the Mini runs $200.Come on... that car is so small you don't even need a lift... just get two strong guys and BAM they can pick it up.
Kenrik
Infiniti G35 Coupe
Nissan Versa Hatch
ACoupe wrote:I replace my plugs every week...
BrandAidDesignG35
Car: 04 Infiniti G35 Sedan
Yo Kenrick...
tell me... Did you do a couple pulls before and after you changed the plugs??? yeilding 15 whp??? That's amazing... I just bought mine, it's at 80,000 KILOMETRES... probably a good time to swap em'
Thanks, I'm also getting the grounding wire kit next week, should be kick-ash along with the F5 fujita intake, I'll have my 5AT performing like it should... and sounding like it should... he he...
Do you recommend the iridium NGK or just stock NGK!?! Thanks all...
grantman240z
Car: '03 G35 Coupe 6MT
Kenrik wrote:That reminds me.. Remember that post on shifting techniques? Well there was a video in there with some kid driving a Mini and I remember him saying "it's better to let your wheels spin rather then feather the clutch because a clutch is more expensive then tires" Well he lost all credibility with me when he said that. Maybe for his crappy little mini with 195/55/14 but not for a real sports car. Just one tire for a G35 can cost more then a clutch kit.. ($250 for a stock clutch kit)
I remember that video as well. The video itself wasn't bad...however, I thought the same thing when he was talking about the cost of tires. My PS2's on the rear put me back about $800...yeah, thanks, I'll be feathering the clutch.
Kenrik
Infiniti G35 Coupe
Nissan Versa Hatch
BrandAidDesignG35 wrote:Yo Kenrick...
Well it's not that I "gained" 15Hp.. more like reclaimed 15HP that had been lost. I have a Intake and a Intake spacer but the top end was still lacking... I think the spark was blowing out due to the gap of the plugs (they had melted so the gap was bigger)
I'l post up pictures later.
infinititech1
i dunno who said 80k or 100k but they are due at the 60k service
C-Kwik
I should be up for a spark plug change real soon on the Titan. I'm probably going to try out the Denso SK Iridiums as they are only 6 cents more per plug than the OE Platinums. They have an Iridium Center electrode and a platinum ground electrode, so wear should be no worse and perhaps better (particularly in the iridium). Iridium conducts electricity better as well so there may be better performance. With the mileage the Titan gets, any increases will be welcome.
zozoka1212
Sounds fancy
zozo
tollboothwilley
Car: 2003 G35 Sedan w/ NAV
I went with the NGK Iridium, and I like 'em so far...
Changed them out about 5K miles ago
smockers83
Car: 2006 G35 Coupe
Yeah I'm not sure who said 100K miles, who ever did is in rough shape. You're supposed to change them at 60K miles.
C-Kwik
tollboothwilley wrote:I went with the NGK Iridium, and I like 'em so far...
The longevity of your plug may be questionable. To my knowledge, there are no NGK Iridium plugs that have a precious metal ground electrode available in the states. At least not through normal distribution channels. While the performance shouldn't suffer during it's service life, the service life may be shortened.
A single Iridium plug is designed for use in an ignition system that uses a single coil and distributor as the spark only moves in one direction. But with cars that have coil packs there is a spark ignited in both directions, so a single precious metal electrode spark plug will wear faster. The Denso SK series plugs have a platinum ground electrode. Their IK has a iridium center electrode, but standard U-groove ground. But it's an ultra fine wire tip which should perform very well, but have reasonable life in a motor that uses a single coil.
Road Ruler
Car: G35 sedan prem
I have 75K on my G. Seems to run fine but will change the plugs soon. Will use stock plugs. What gap is optimal?
thnxs
TeflonG35
Car: 2003 G35 Sedan
The NGK Iridium plugs don't have to be gapped right? I thought I read that somewhere. I could be wrong, i haven't changed mine yet, though they will be due soon. Curious because i will be changing them soon.
tollboothwilley
i had to gap mine...
93jdirty'
Car: 1993 Infiniti J30
[QUOTE=Kenrik]
Well it's only $30 for the stock plugs and $60 for NGK Iridium. where did you find plugs that cheap? for all 6?
C-Kwik
I believe the gap for the G35 is 0.044". Plugs with precious metal on either electgrode shouldn't need to be gapped. They are typically gapped from the factory to the required setting.
It is not advisable to gap one of these plugs unless you know what you are doing as it is somewhat easy to accidentally pop off the button of platinum or iridium on the plug.
joe603
Car: 2014 Durango R/T
What about indexing??? Do you think that's necessary with the VQ35?
Road Ruler
Car: G35 sedan prem
Thn
C-Kwik wrote:I believe the gap for the G35 is 0.044". Plugs with precious metal on either electgrode shouldn't need to be gapped. They are typically gapped from the factory to the required setting.
thxs for the info CK!
cweberj30t
Car: 1993 J30t
2003 G35
2007 G35X
2011 G37X
Just changed last night. I have 71k on my sedan. Used the NGK Iridium. Took me an hour and 15 mins to do all 6. Would have been faster if I could keep my plug socket from sticking to the plug and coming off my socket extension. Old plugs looked somewhat fouled and there was rust where the porcelain meets the metal. Noticed smoother idle and acceleration, especially when cold...its freezing here in Chicago! I would say over 60k it would be good to change. Advance Auto had the best price on Iridiums.
srv2nv
I'm planning on doing my spark plugs this weekend along with a few parts that I've been collecting.
Anyone have any tips/tricks for removal/installation of the spark plugs? (ie. watching out for something that is in the way or should be removed or how to get anything out of a tight spot)
Also, whats a good spark plug to go with? In the past I've always gone with the Bosche Platnium 4's and have been happy with them. Do they seem like a good choice for the G35 aswell?
Tampa G35 Sedan 6MT
Car: 2006 Infiniti G35 Sedan 6MT Black w/ Premium & Areo Pkg
1989 Jeep Cherokee 4X4 Lifted and Old School!
Good to know
WESIDE
Car: 2006 g35 coupe
Has any one installed the HKS Super fire raceing plugs. I am only at 20k on my 06' coupe but am ready to change the oem plugs out. At almost 23 dollars a plug they are pricey but are these worth the cost or am I just throwing my money away. Here is where I found them http://www.stillen.com/product...202DR
Wes|de
pae9132
Car: Modified 03 V35
check this out everyone before you buy your plugs...The march 2008 issue of DSport tested the new "Pulstar" spark plugs on a 2004 g35 six speed and got just under 5 extra horses at peak but also got almost 10 extra at 5200 RPM. they had NGK Laser Platinum plugs from the factory before the test
WESIDE
Car: 2006 g35 coupe
Bump. Anyone used the HKS plugs or have an opinons on these?
