I have a 1996 Pathfinder. I had the radiator replaced last Summer and have noticed that the hoses on the transmission oil cooler are now leaking coolant. I was considering just replacing the hoses, but then realized the oil cooler appears to be stock and a bit worse for wear. I wanted to ask if anyone would recommend replacing the whole unit instead of just the hoses? If so, can anyone attest to whether this is a challenging install? It seems pretty simple just by looking at it, but, again, I thought I should ask.
The transmission went out a few years ago and I had it rebuilt. I've noticed that it does jump from time to time when putting it in reverse, so I want to do all I can to make sure that this rebuild lasts as long as possible.
Any tips, thoughts, and suggestions would be greatly appreciated!
~ Andrew
