onosqv »
https://forums.nicoclub.com/onosqv-u507.html
Thu Jan 08, 2009 9:08 pm
If you have another sohc engine around that is in good working order & you are comfortable enough to do an engine swap, go for it.
Otherwise, you can always start tearing down the engine (i.e. being doing a timing chain replacement) & check the head/cams/etc while you are at it.
With the valve cover removed, and potentially the timing cover removed, crank the engine by hand w/ a large ratchet and see if anything hits - it will be fairly obvious if something is really badly wrong.
For more exact mechanical tests, you can consult the FSM, which will tell you what to test, how to test, etc.
