replace tension rods
computerking
I found a how to on this site but need some advice as to which parts to buy found some adjustable ones on ebay for about 100usd and some others for 300usd and nissan want about 350usd for the oem ones.
nsrZ32
Car: 90 Nissan 300ZX TT
78 Datsun 280Z
71 Datsun 521 Pickup
98 Nissan Sentra 2.0 SE
02 Nissan Altima 3.5 SE
01 Ford Focus S2
The 100 dollar ebay ones aren't very good quality and buyint OEM ones is silly. Check out SPL Parts, http://www.splparts.com/ they make the best Z32 suspension components on the planet.
Booztd 3
Car: 1990 Nissan 300ZX TT
I have heard of some SPL tension rods breaking before, its not a common case, but it has happened. To date the only tension rods I know that have no documented failures are the powertrix ones.....
nsrZ32
78 Datsun 280Z
01 Ford Focus S2
^ in extreme situations anything could break made by any company.
SPL still is #1 in my opinion.
freakonaleash1187
Car: '93 300ZX N/A, '97 200SX SE
SPL adjustable tension rods are #1, I have the Version 1's on my Z and they are good quality, and now they have Version 2's out, which are bigger and better.
Dano
Car: '05 Nissan Frontier Nismo CC
'95 Nissan 240SX base
Booztd 3 wrote:I have heard of some SPL tension rods breaking before, its not a common case, but it has happened. To date the only tension rods I know that have no documented failures are the powertrix ones.....
Those were the old version 1s, which Kuah (Owner of SPL) immediately got remedied, with the birth of the 32mm thick version 2s. I love my v2s.
I've heard of tons of powertrix pieces cracking/breaking. One of my friends broke some without impacting anything, also cracked some of their RUCAs and trailing arms with only spirited driving. I think the only ones i've never heard of a problem with are CUSCO and of course, the version 2s from SPL.
SPL ftw!
-Dan
freakonaleash1187
I should probably get my Version 1's replaced sometime since I will be taking my Z to the road course.
computerking
Thanks everone i order v2 from spl should be arriving soon. Downloaded the how to and think i will attemt to do this job myself anyone got any words of wisdom for this. I am not really great at cars but will do it save some bucks, and i do love my new 300zx so mabey she will be kind to me and make this job easy and enjoyable.
freakonaleash1187
From what I can remember (its been almost 3 years since I have done mine), all you have to do is take out the two bolts where it is connected to the wheel and then take out the bolt where it is connected to the subframe. The bolt that connects it to the subframes is pretty long, which makes it difficult to get out since the dust shield is right there, it inhibits you from getting the bolt out easily, it just takes some force.
nsrZ32
78 Datsun 280Z
01 Ford Focus S2
Also, make sure you get an alignment right away after installing the new tension rods
NSR_s30
Car: '99 Ford F250 7.3L Diesel
'71 Datsun 240Z
nsrZ32 wrote:Also, make sure you get an alignment right away after installing the new tension rods
computerking
Thanks again fellows got my spl v2 rods in the mail today whoopee going to take to my friends shop tomorrow afternoon to install them. Some how to's state that the whole assembly be removed including the swaybay bushing bracket guess i will find out tommorow.
freakonaleash1187
You do not need to remove the whole assembly or the sway bar brackets, it can be done by just removing the three bolts, thats how I did it. But, like I said, that really long bolt is really hard to get out because of the dust shield. I'm sure if you removed the whole assembly, you wouldn't have that problem.
ArticDragon192
Car: 91 Z32 2+2
There are also he Peak Performance ones. I just got them installed on my Z. Here are the pics I took. Beefy as hell too. And uses Aurora ends.
Wimpy wimpy wimpy...
Hefty hefty hefty
Comparison shot
And installed! Ballin' with the gold.
computerking
GOT THE RODS IN!!!were is the best place to get the alignment done living in Calgary alberta canada
computerking
FRAME KING
