Replace reverse lamp 1996 J30
sugarsugar11
Car: 1996 Infiniti J30
The driver side came off easily, the passenger side will not budge. I tried everything - including the screwdriver with cloth, wire under the lamp and pull, etc. with no success. I'm almost afraid of forcing and breaking the lamp assembly. The paint gets scratched off under the lamp assembly, even with a cloth over the point of the flat screwdriver. Any other way of taking the lamp assembly off on the passenger side? Thanks.
driverdriver
Car: NICO's longtime resident Canuck!!!
I believe these lens are plastic.
Get your self a blow dryer, set it to hot and heat up the edges while gently pushing under the lens with a small flat screwdriver. It should work. Evening when things have cooled down a bit is the best time to try this method, especially after dousing the both lens with cold water from a garden hose.
1994 infiniti j30 190+
Car: 1994 Infiniti J30
1990 Ford Ranger XLT Sport Limited Edition
idk if yours could be doing this but on my car the braket that holds the lamp in was very rusted on mine and i almost couldnt get it out but it finally let go and came out. that could be your issue. idk how much room is behind the bumper but if you could reach behind the bumer and try pushing it out while someone trys to pry it out the accual way it may help. and maybe spraying pb blaster or wd40 in there may also loosen the rust up and help get the lens out.
sugarsugar11
Thanks for the suggestions. I will try the hair dryer, PB blaster and bumper routines, and report back.
Thanks again.
nosaint
Car: 1992 Nissan Leopard
hot glue a wooden stick to the lens...pull it out and then pop it off...might work
