Replace pilot bearing?
Tartan
Car: 89 240sx
Ok, from what I've read on the boards it seems that I need to replace my pilot bearing. My clutch seems to make a "whirring" sound usually when shifting between 1st and 2nd. Sometimes at idle when I depress the clutch to put it into gear. It's extremely loud when I rev the engine with the clutch depressed. To be sure is that the pilot bearing or something else? I just want to be sure before I go through the trouble of dropping my transmission. If it comes to it what kind of hints could you guys offer on removing my transmission that could make it alot easier? Thanks.
UsedToOwn240SX
Car: Radio Control Racing, Counterstrike
If the noise is present more on shifting, I think it's the throwout bearing instead.
Cyberkreig
Car: 1993 Nissan 240SX SR
Replace them both while you are in there, trust me on that.
Tartan
Car: 89 240sx
Well the thing is I already put a new throw out bearing in when i replaced the clutch. Do you think I need a new one already? Its only been like 60 miles on the new clutch. I've been super easy on it too.
Holisticbeatz
Did you get your flywheel resurfaced? Cause that could cause vibrations and whirrly sounds if you didn't.
Cyberkreig
Flywheel is definatly possible.. T/O bearing not seated properly.. worn pilot bushing could allow shaft wobble..
If you just replaced it, you probably dont need to again. If you were just in there recently then you should know about the condition of the pilot bushing.. and if it is POSSIBLE the TO bearing isnt on right.
Tartan
Car: 89 240sx
Alright, I'm just not looking forward to it though. Thanks guys.
