maxhopper »
https://forums.nicoclub.com/maxhopper-u11180.html
Sun Dec 13, 2009 9:54 am
According to the directions in the Chilton's manual, it will not be easy.
It goes something like this:Evacuate A/C system.Drain the cooling system.Disconnect negative battery cable.Disconnect heater hoses from heater core and remove rubber grommets from the heater core.Disconnect A/C lines and rubber grommets.Release clip that hold water control cable, push cable through firewall.Remove lower dash panel and lower steering column. Remove instrument cluster and reinforcing bar.Remove floor heater ducts and brackets.Remove the PCM.Unsnap the duct from the bottom of the heater core housing.Remove the evaporator core housing.Remove bolts holding heater core housing to firewall and remove cables.Pull down and back and twist till it comes out.Replace the heater core.Put everything back together making sure none of the cables bind before you get everything installed.
