NycQX4 »
https://forums.nicoclub.com/nycqx4-u282387.html
Sun Apr 01, 2018 7:20 am
Hi,
Last week my 02 QX4 stalled while driving on the highway. After I pulled over to the side, the car would start but can not hold idle. Luckily I had a code reader and reset the ECU. The car started and but had a high bouncy idle between 1500 and 2000.
I drove the car to my parking garage and did some research. It seems likely the IACV is the culprit and if left unchanged, can damage the ECU. At my garage, I did the idle air relearn procedure and now the idle is fine. My question is, should I go ahead and replace the IACV anyway or just replace the IACV motor or should I wait till the problem happens again?
My concern is that I have a hard time removing the throttle body bolts. So, I’m afraid replacing the whole IACV asembly might break something. Looking at the assembly, it seems the motor can be removed and that’s the part that seems to cause the ECU Problem. Is there any issue if I just replace the motor and switch for the IACV?
Thank you ahead of time.
