Replace Fuel Filter
oxs1
I just recieved a fuel filter from Joe and i was woundering how to install it for a 91 q45. I also wanted to know if i can ohm injectors from the injector itself as i want to buy some used ones from a junkyard.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Replace the fuel filter by pulling the fuse for the fuel pump while the car is running, the car will stall, crank it a couple more times to verify all pressure is lost... Then pull the hoses and replace... The filter is mounted on the pass side strut tower.....
You can ohm the injectors from themselves... Put your multimeter on the lowest ohm rating, and do it onthe 2 pins.. doesnt matter which probe goes where...
