DAEDALUS wrote:Most rotors have 2 holes in the face for you to thread 2 screws into to push the rotor off the hub. Don't know the threads offhand, but the manual should say. They'll be metric, probably 8, 10 or 12mm. Consider this if the rotor's being difficult. Or do what most people do and crank the hell out of it with a hammer. I don't like the hammer approach--don't know what's getting damaged.
I had this problem, tried the BFH approch and just chewed up the hammer. One rotor was off (easily) but the other was not budging for anything. So I went to Autozone, with the old rotor, and they coudl nto find a thread that matched at all. Infact al they did was bodge up the thread a bit. Kragen were no help either.
Finally however, HOME DEPOT had all the ranges of 10mm and 12mm in 100, 125 and 150 pitch threads and it turns out to be the 10mm @ 125, they are abotu $2 each for a pair of 60mm long one. These then worked like a charm and even fitted my new after market rotors for next time.
